david lamontagn
03.05.2008, 08:40 PM
Try to put the "Automatic correction of neutral" at YES and try it again.
And as i can see, with the newer version, we have the "No Brake" option?
That's good when we use mechanical brake!!
lutach
lutach's Avatar
03.05.2008, 09:26 PM
Actually I just double checked the check marks on the manual and I have H as YES. I sent an e-mail to Mr. Grisa and I will wait to see what he'll say and I also sent him a link to this thread.
Topas
03.06.2008, 12:08 PM
Look at this funny current values ;)
If my eagletree logger is correct, the max current was 89 A ... (10 samples per second)
300A or 180A is impossible for my old 14cell nimh !
lutach
lutach's Avatar
03.06.2008, 12:39 PM
That is something. I received an e-mail from Mr. Grisa and he said for me to set the neutral range at 12%. That didn't work. I will make a new video of everything from programming to the problem.
Topas
03.06.2008, 01:47 PM
It didnīt work for me either . But I did not get a reply to my email yet .
lutach
lutach's Avatar
03.06.2008, 02:03 PM
Yours is running good now after you you made the change in the brake setting, but did you set it for B: 7 or B: 5? I'm going to try a few other changes to see if it helps.
lutach
lutach's Avatar
03.06.2008, 02:24 PM
I tried to see if adding drag brake would help, but now the car just accelerates without me applying brakes. The faster it goes in forward the faster it'll spin when drag brake is applied.
Topas
03.06.2008, 02:54 PM
I donīt know what you mean with B 7 or B 5 - donīt you see my image of the settings ?
