03.08.2008, 02:09 AM
Keep in mind that MGT spur gears fit very easily. Just use a 5x10 bearing, instead of the 5x11, and drill 3 of the peg holes to 5mm. Work like a charm and are 46t to 52t, so they will allow for the larger can motors to fit!
MetalMan
MetalMan's Avatar
03.08.2008, 02:43 AM
I wonder how you found out about that?
ssspconcepts
ssspconcepts's Avatar
03.08.2008, 12:39 PM
Thanks guys...I guess it slipped my mind about the MGT spur gears...Now that you reminded me, I do recall someone mentioning it. Good call....I have plenty of 5X10 bearings and 5mm drill bits!
03.08.2008, 01:11 PM
Well, I actually looked at every mod1 spur the lhs had, and decided that the mgt gears looked good. I driller the first one out in the center for the std 5x11 bearing and enlarged the peg holes.
Same night that I did the mod I also saw it on the forum, and also found out that the 5x10 bearing could be used. So I guess that it was a little bit of both!
MetalMan
MetalMan's Avatar
03.09.2008, 02:08 AM
Ah, I see. Great minds think alike
03.09.2008, 03:58 AM
Fools seldom differ! Thats what my grandpa always said when we both came to the same conclusion!
