david lamontagn
03.10.2008, 05:35 PM
OK thank you guys!! So i'll use the elekti-clutch, like that i'll can install the center diff in a more conservative position.
And today i've work on the piece of aluminium, and you'll be surprise by the final result
Sure it'll not as good as a machined piece but for an hand made, it'll be not to bad
Lonewolf039
Lonewolf039's Avatar
03.14.2008, 11:01 PM
So, made any progress on this? I am anxious to see how it turns out.
BTW, a 5/8" drill bit is 15.88 mm. That is what I used for my bearing holes, and then just carefully opened them up for a snug fit with a sanding drum on my dremel. For $96 you could have bought a cheap drill press and some drill bits, then you can make all the holes you want
Patrick
Patrick's Avatar
03.14.2008, 11:31 PM
Yep, I used a 5/8th drill bit for my motor mount bearings holes as well, but before I got a drill press. Drill press makes things a lot easier.
david lamontagn
03.15.2008, 02:19 AM
Don't make me remember this OK
