jhautz
jhautz's Avatar
03.12.2008, 01:47 PM
I'm interested to see what you find with this.
I have Xray XB8s in both BL and Nitro also. (actually 3 of them, 1 nitro, 1 bl with conventional motor brake setup and, 1 with BL and mechanical brakes and a TeknoRc clutch setup.)
What I found was I was faster with the BL, but I atribute alot of it to my driving style. I have always been an electric guy and tend to try and drive with the smoother throttle style that goes with electric. This doesnt really lend itself to being fast with the nitros. From what I see, typically the fast nitro guys are very harsh with the throttle, almost like an on off switch. They are either full throttle or none at all. I just cant get used to driving like that, so I find myself to be more sucessful getting round the track clean and as fast as I can with the BL. Like you I prefer the mechanical brakes on the BL though. So soon I will be braking down the 2 BL XB8s and taking the Mechanical brakes from the clutched version and putiing it on the conventional pinion drive buggy and making what I think will be the best setup for my preferences.
Please do update this once you have driven them back to back. I actually find that it takes me 5-10 minutes of driving to actually get the mental adjustment down when going from nitro to BL or Bl to nitro on the track.
Please take all of this with a grain of salt folks. I am by no means what I would consider a fast/good driver. Not an even an a-main guy at the local track. (But getting better all the time ) This is all my opinion and what fits my driving style.
to make it...
or break it...
Silent...But Deadly
Shark413
Shark413's Avatar
03.12.2008, 02:13 PM
jhautz, I agree with your statement regarding driving style. Nitro requires more on/off style as you stated because of the spool up required by the nitro engine/clutch, it doesn't deliver optimum hp/torque until it gets into a specific rpm range (high). Nitro requires more blipping of the throttle to keep the rpm's up. Electric on the other hand has almost instant torque and requires a much smoother throttle. Nitro engagment is more muted, because of the spool up required to reach the right rpm, and the clutch slippage. Electric has no delay and feels more powerful and can lead to excess wheel spin if not controlled. The electric buggy is heavier, because of the battery and the suspension, and has to be setup differently to account for that. In my experince they require totally different driving styles. This translates into different lines, brake points, etc.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
jhautz
jhautz's Avatar
03.12.2008, 02:51 PM
I agree whith what you just said except for the fact that the electric buggy is heavier. Mine are very close to the nitro weight within a couple onces RTR. So the weight really isnt the issue, but the balance of the buggy is certainly a little different requiring a different suspension setup to be effective.
to make it...
or break it...
Silent...But Deadly
Shark413
Shark413's Avatar
03.12.2008, 04:34 PM
jhautz, that is very interesting regarding the weight. Without a battery both my buggies weight almost the same. But the 4s2p 6000mah lipo weights 590grams and that makes it heavier. I admit I have a really heavy duty battery tray and motor mount and probably could have saved a few grams, but not enough to make up for the 590gr battery. I am going to weight the individual parts and compare them (nitro motor vs brushless motor, radio box/fuel tank vs battery tray/ESC, etc.). I always assumed the nitro gear removed (engine, bell, fuel tank, radio box, pipe, etc.) offset the brushless stuff added (motor, mount, battery tray, ESC) with the only exception being the lipo battery weight.
jhautz
jhautz's Avatar
03.12.2008, 04:52 PM
2 sugestions...
less aluminum
more CF
My truggy is actually almost a half pound lighter than it was in nitro form.
to make it...
or break it...
Silent...But Deadly
lutach
lutach's Avatar
03.12.2008, 04:58 PM
My CF truggy weighs 5-6 pounds depending which battery I use.
