MetalMan
MetalMan's Avatar
03.12.2008, 08:16 PM
How do the weights of the actual buggies compare as rollers? I know they are similar (Kanai III vs 777), but I wonder if different parts make the Kanai III heavier.
Shark413
Shark413's Avatar
03.13.2008, 02:11 AM
MetalMan, my Inferno 777 SP2 (nitro) weights 7 lbs 12.4oz (no fuel or rx battery). The Kanai III (brushless) weights 7 lbs 12.6oz (with no battery). So like I said most of the weight difference is in the lipo battery.
Non-Stock parts:
777 SP2: Fioroni shock towers, Steering plate. Reckward chassis braces, CEN CNC knuckles, CEN 16mm Big Bore shocks/RMV progressive springs. Kyosho bonded brakes.
Kanai III: Racers Edge shock towers, Racers Edge Toe in plate, King headz chassis braces, Knuckles and C-Hubs. CEN 16mm Big Bore shocks/RMV progressive springs, Craddock fiber rotors, K-Factory hinge pins. King Headz steering plate.
yeah so there is a lot of extra aluminum on both buggies. I went for a little extra durability over super light weight.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
