david lamontagn
03.14.2008, 12:08 AM
Hey Lonewolf039, do you have the RCM hybrid truggy diff in your revo???
Because i've look to make a system like your's but i need a 4.3 diff ratio to don't have to put a 5T pinion and stay in the 40 m/h range
ThaMule
ThaMule's Avatar
03.14.2008, 03:15 AM
Awesome build bro. I am waiting on my stuff to get here so I can get mine up and together. I already bought the emaxx tranny for mine but i like the looks of this if I can get the motor mounts made somehow (hard to do in the sandbox). I guess I will find out though. This looks awsome though.
Lonewolf039
Lonewolf039's Avatar
03.14.2008, 08:58 PM
Yes, I am using the 4.3 ratio hybrid truggy diffs. Like you said, it's the only way to get the gear ratio in a decent range. They are awesome, the machining is top notch, and the HB diffs are way beefier than the Traxxas diffs.
BTW, the Traxxas cvd's fit in the HB diff outdrives perfect, but they are a little short and barely stay in, so I used the RCM adapters and the Traxxas dogbone cups. I am curious as to how the Traxxas cvd's will stand up to brushless power.
Lonewolf039
03.14.2008, 10:46 PM
I installed the fan on the MM, and ran a pack in the hotel parking lot. It sure is sweet to just walk outside with the truck and controller and let it rip. I probably don't need the fan, but was bored so I put it on. I can always take it off again. I should have taken the pics before running in the snow
Here is a pic of the Traxxas cvd's using the HB dogbone cups. You can see that it is a little short. The bone hasn't popped out yet, but it could.
And here is the front with the Traxxas dogbone cup. It is a bit longer and holds the cvd better.
Next time I have the rear diff apart, I will change the dogbone cups to the Traxxas ones. Too bad I have to split the bulks to get the diff out.
SpeedAssault
SpeedAssault's Avatar
05.24.2009, 11:57 AM
Very good build thread, enjoyed reading, easy to understand and Follow.
great pics.
Thanks for listing all the specs including the ratio's and , motor, speed and such. It really makes a great thread complete.
This is how Threads SHOULD BE
Nice job !
05.26.2009, 10:07 AM
There is no rule stating everyone has to make their build thread a 'How-to' guide for other less imaginative/ talented/ mechanical minded people to follow. Seriously, bolting a 1/8 center diff to a flat piece of metal isnt hard, nor is mounting an MMM and hooking up a pair of 3s lipos in series...
