Jbreddawg
Jbreddawg's Avatar
03.15.2008, 01:31 PM
Excellant work !!!
03.15.2008, 02:48 PM
Very interesting David, I thought that you were going to use a center diff? I see why you used the revo output shaft, to keep the stock center driveshaft length!
Also like the use of a bulkhead to do the mech brakes. Lokks good, can't wait to see it finished!
Lonewolf039
Lonewolf039's Avatar
03.15.2008, 09:39 PM
BEEFY!! I like. Looks really good. You should be able to make a lexan gear cover for the center gears real easy.
david lamontagn
03.15.2008, 11:47 PM
Very good idea lonewolfe, i've don't think to this
david lamontagn
03.15.2008, 11:50 PM
My first idea was to use a center diff, but it's quasi imposible to install a rear mechanical brake, the motor take all the space. And i don't want to use the controller to brake.
So i decide to make an adaptor and having an all time 4wd.
03.16.2008, 09:49 AM
I hate to bust balls here but someone has to say it, locking a revo tranny in second would have accomplished the same thing and been much simpler, that being said, its nice work and a great accomplishment, there are center diffs for revo trannys as well that would allow front and rear brakes.........
83gt
03.16.2008, 10:35 AM
Except this looks to be about 100x stronger, and looks WAY cooler ;).
J.
03.16.2008, 11:34 AM
absolutely agreed
Just go Play
Just go Play's Avatar
03.18.2008, 10:51 PM
Speaking for myself I find that the revo center diff is worthless when running a powerful BL motor. Too much power gets wasted due to excessive power going to the front wheels spinning instead of to the ground.
I need to pick up a 1/8 diff to play with to see if I can get the diff action under control. After seeing David's setup I may try something similar but fitted with the center diff.
MetalMan
MetalMan's Avatar
03.19.2008, 02:27 AM
Like this?
http://smg.photobucket.com/albums/v132/4x4pede/Revo/ (lincpimp is the current owner)
David, yours is coming along nicely! My only criticism is that you call it a "sliperential", yet I see no center diff . Any plans for installing one?
Just go Play
03.19.2008, 03:48 AM
Originally Posted by MetalMan View Post
Like this?
That is a nice compact setup and it looks to shift the weight off the rear end... hmm gears turning now. Is there a noticeable difference in how the CD acts when the motor is mounted center chassis as opposed to the stock location?
I don't want to jack this thread so MetalMan if you could pm me I'd like to pick your brain a bit if possible?
Cowboy
03.20.2008, 12:31 PM
I was building 1/8 scale revo center diffs before traxxas came out with their own. They were based on a thunder tiger ttr s3 buggy diffs and they worked awesome. I still have some parts and blue prints if anyone is interested. You can pm me for pictures.
