Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
Shark413
Shark413's Avatar
03.17.2008, 02:15 AM
Regarding the pinion clearence, one of the biggest issues using mechanical brakes is that because of the motor can hitting the disc there is a limit on how small you can go on the pinion. I solved this by spacing the motor back a few milimeters so that it clears the disc and therefore I can run very small pinions (10, 11, 12, 13T). Since I am running the Kyosho 46T spur and a hot running Feigao I need to run a 12 or 13T pinion. This also eliminates clogging. On the downside, this setup puts the pinion on the very end of the motor shaft. Because of this I built up the motor mount/chassis to be extra stiff (no flex). So far I have had zero issues with this setup.
This is a 13T pinion.
These pictures show the test fitting and the rough parts (motor mount).
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
jhautz
jhautz's Avatar
03.17.2008, 10:25 AM
Looks good shark. That is the solution I was trying to describe a couple posts ago.
Last night I sketched up a spacer plate for the front of a motor that would allow for the brake disk clearance and just sent it to Mike to see if he could machine one up for me. It should allow the use of an almost full range of pinion gears. At least down to 12T by my calculations. It should be able to bolt up to just about any motor using a normal bolt pattern and with any of the RCM style motor moounts allow clearance for brake disks. Like you said though shark, it will put the pinion farther out on the shaft, but I have been running a really long Tekno clutch assembly in one of my buggies which effectivly almost doubles the shaft length where the pinion gear is and havent had any issues so I would think this should be fine too.
Heres the sketch of what I'm thinking.
Name:	Motor Spacer for Brake disk.jpg
to make it...
or break it...
Silent...But Deadly
