03.17.2008, 07:28 PM
Q. Its hard to tell from the pics, but is there a little lip or narrowing on each piece to prevent the bearings from just sliding out?
I like the motor support feature, clever thinking- just needs to be height adjustable with shims or washers, buts thats simple enough.
Jbreddawg
Jbreddawg's Avatar
03.17.2008, 08:01 PM
There are no lips as of yet . This one is really just a prototype to get my ideas figured out. I just got my drill press set up to do some minor milling so the next one will have a lip on the outside to stop the bearings. These holes I had to use a dremel sanding drum just to get them to size lol .
Heres a new pic of the rear support , the second one I do will be a 2 piece , basically the bottom half mounts solid and the top half with adjusting slots just like a motor mount. Now I can mill half of each so it will still look like one piece ! Sometimes I just work on stuff at lunchtime at work to see what I can come up with and sort it out later. Jerry
Photobucket
Photobucket
