azjc
03.21.2008, 06:30 PM
Originally Posted by Just go Play View Post
I'm in the same boat with you Dicky. For the moment I have chosen to run the solid center shaft as I just lose too much power using the CD. I don't think that there is a way to get the revo CD to work well using the 1Y on 5s as it is just too much power for it to handle.
I have found that by using a little punch control and carefully setting the slipper that so long as I don't nail the throttle the wheelies are not too big a problem. I'm also toying with a couple ideas for using a 1/8 scale CD which will handle the power better and should be a much better solution.
Have you tried the Duct Tape mod for your tires to prevent the balloning? it doesn't get rid of it completely but it does help
DickyT
03.21.2008, 11:16 PM
duct tape, gaffers tape, all weather duct tape, gorilla tape, it rips any of it off in about 30 seconds of WOT.
azjc
03.22.2008, 10:47 AM
Dicky T
just an idea I had while reading your post, try applying some type of glue/resin to the inside of the tire to cause the rubber to harden/stiffen, and reinforce, put the tire back on rim similar to the Duct tape mod and possibly use beadlock style rims( this may make it easier to get back on the rim) they have some at Impact, here is a link
http://www.impaktrc.com/product_info...roducts_id=183
I would try this myself, my Revo is still the beginning stage, I still need to remove 1st gear, do the FOC, and CD mods to the tranny and remove the gas componenets from the truck, the only things I need are the motor/esc
