Sammus
Sammus's Avatar
03.22.2008, 08:20 PM
Originally Posted by loa View Post
Thanks Sammus!
So the 4s 4000 20C would have as much power but would have roughly half the runtime as the 4s 8000 10C.
Ok. Another related question: what range of speeds should I expect with a 80amps battery in a e-revo using MM and 9XL?
Nothing specific as I know it relate to the gearing, but I'd like to have a revo that reaches somewhere around 35mph.
Does anyone know if the 4s 8000 10C can achieve that?
Thanks,
Loa
I think 80A wouldn't be enough to get it moving initially. Maybe if you were using the tekno clutch it would, but a big truck requires a bit of energy to get moving, and I suspect that spikes would be well over 100A if you floor it from a stand still. for 8000mah batts I would want at least 15C, preferably 20C. I think youll be able to get 35 out of it with that setup OK. I'm pretty sure I've seen some builds with nearly that exact combo, may want to have a look for them or something because this is all speculation for me now :)
83gt
03.29.2008, 06:04 PM
Myself and several others are having good experience with the 8000mAh TrueRC packs. Although they are only rated at 10s, it seems they can do much better. They are a whole world better than the 20/30c maxamps 5000's I was running, all else the same. Somewhere around half the cost too :).
J.
