crazyjr
crazyjr's Avatar
03.23.2008, 04:49 PM
I got the same problem with an 8000 2s maxamps lipo i got. after talking to someone from maxamps, we determined that due to the age of the battery, a cell was dying. I let the balancer run for overnight and it finally balanced. What is probably happening is the same as me, Mine is a 2p, not sure about you. But the good cell is overcharging and causing a safety cut-off. Mine did with different balancers and chargers. I let it balance overnight, topped it off then took an hour to balance then topped it off again and it balanced almost immediately. I was told it would be safe till it fails to balance or it swells
