lutach
lutach's Avatar
03.23.2008, 11:47 PM
Originally Posted by DrKnow65 View Post
Can you post a few links for the pumps you've found? I see the TCS pump but have had no luck reaching them for more info. I'd like a cost effective alternitive to the TCS pump.
I will search my e-mails to get the data sheets of them. It might take a day or two, because I contacted the manufacturers a long time ago. I usually keep my company's e-mails organised, but I have no clue where I put the e-mails I got from them .
Edit: Here are 2: http://www.alita.com/dcpump/micropump.php and http://www.chinamicropump.com/
I will have to search for the others as I contacted them in 2003.
03.24.2008, 12:01 AM
Wow, best of luck with the recovery. I burned my hands on a fixed gill pit at a park when I was young, took almost all of the skin off both palms. Luckily I was hit by a car the year later and have no memory of my chilhood (8yrs and younger). I have very little hot/cold sensation in my hands, but have devoloped much stronger tactile sesation to make up for it. That is handy as I do auto paint and body work and it is very handy (pun?) to be able to feel the surface for imperfections.
I really hope that you get better and regain most if not all use of those fingers!
If I had a monkey butler he would be on his way to you, but the ASPCA took him away
