03.24.2008, 12:51 PM
Using two seperate balancers is not a good idea IMO because a balancer works by discharging high cell(s) in a pack. It works off the relative voltage levels, not some absolute value. So, if two cells on one pack were at 3.7v-3.7v, and the other two in the other pack were at 3.5v-3.5v, each pair would be balanced, but not to each other. The only way this works if there is a way for the balancers to talk to each other, like in the LBA balancers.
However, you can use the 4s single unit balancer. From the picture you posted, I think it should be hooked like this:
jefierro
jefierro's Avatar
03.24.2008, 02:09 PM
Sorry I should have explained my self a bit more earlier, the green boards are not balancers just balancer tabs connectors, Align/Equinox type if you must, not the same as the Hyperion tabs. The withe tab in my image connects directly to the equinox balancer, and this is the only link for the batteries to the charger. these adapters and balancer are rated up to 6 amps using both the main lead and balancer connectors.
my lipos are two maxamps 2s 5000mAh with align/equinox tabs (3 pins)
This adapter, so I intend it to be, a solution to charge and balance two 2s lipos as one 4s lipo at 1C(5amps) so the use of the main leads and the balancer tabs are needed to distribute the current over more wiring to eliminate heat at the connectors. Hope this will explain my intentions.
thanks all.
  Send a message via MSN to jefierro
