Gustav
Gustav's Avatar
09.08.2005, 04:45 PM
Originally posted by Papa
After looking at the scorion manual it seems like the speed control connects directly to the battery. Then there is a 3pin plug from the batterry that connects to the channel 2 slot on the receiver. It sounds like when running two packs in a series we would have to have some sort of a Y connector between both lipo packs and the speed control and then another Y connector betwwen the packs and channel 2 on the receiver. Is my thinking correct so far? :C:
@Cool this is a good thread on the lipo nomenclature lipo
According to FMA,you don't use a y-harness to connect the LVC wires when using multiple scorpion packs in series.
They have a standard response e-mail explaining the connections,you basically just daisy chain the LVC wires from the 2 packs together.So one pack plugs into the ESC,the other into the reciever and the 2 packs just plug together.(no additional wiring needed).This was my understanding from their e-mail anyway.
If you send them an e-mail asking how to connect the LVC wires when using multiple Scorpion packs in series then they'll send you the standard response so you can check that i haven't misunderstood.
I was confused by their reponse at first because in many pics of the packs you can only see one LVC wire but if you look at the manual there appears to be 2,one to the ESC and one to the reciever,as you said.
You only need one y-harness not three.(deans harness to connect power wires in series)
