fkadir
03.25.2008, 08:41 AM
Just got the 16018 back with the new 3.21 software. No issues with braking so far. Have set the car to forward and brake only. Running on 5s. The cut-off issues have also been eliminated. :)
david lamontagn
03.25.2008, 12:41 PM
Great to ear!! Hope that mine will run as fine as your's. But i use the mechanical brake on my revo, so i'll not test the brake anyway.
I suppose to recieve mine this week
Which radio you use fkadir??? a normal FM or a 2.4?
Me i use a Futaba 2.4 FASST 3PM.
Countryhick
03.26.2008, 06:41 AM
Can anyone who has the latest firmware confirm that the issue with using a Futaba radio in "HRS" mode has been resolved. For those that don't know the older speed controls would not recognise the HRS signal and you would have to change the modulation to PPM or PCM.
Regards Andrew
david lamontagn
03.26.2008, 12:49 PM
Regards Andrew
The HRS mode is usefull only if you run digital servos
If you use normal servos, donK't use HRS mode or you'll smoke your servos.
And if you have digital servo, you can run in PPM mode and all will be fine with the MGM
Countryhick
03.27.2008, 02:39 AM
Thanks David. Is there anyone that can confirm the new firmware works with HRS?
Regards Andrew
fkadir
03.26.2008, 09:15 AM
Im using the Airtronics M11 with the 2.4Ghz module. Hope yours comes in soon. :)
