david lamontagn
03.26.2008, 12:49 PM
Originally Posted by Countryhick View Post
Can anyone who has the latest firmware confirm that the issue with using a Futaba radio in "HRS" mode has been resolved. For those that don't know the older speed controls would not recognise the HRS signal and you would have to change the modulation to PPM or PCM.
Regards Andrew
The HRS mode is usefull only if you run digital servos
If you use normal servos, donK't use HRS mode or you'll smoke your servos.
And if you have digital servo, you can run in PPM mode and all will be fine with the MGM
Countryhick
03.27.2008, 02:39 AM
Thanks David. Is there anyone that can confirm the new firmware works with HRS?
Regards Andrew
