DrKnow65
DrKnow65's Avatar
03.28.2008, 05:48 PM
Yah luatch, me too (note my signature). It's gonna cost a small fortune to build these in prototype from aluminum, but some of the harder bits can be plastic and some CF in production. I've got to keep the cost down if I want to sell any and have any chance of making cash on them.
lutach
lutach's Avatar
03.28.2008, 06:03 PM
Some plastics have come a long way and I saw a show about some pogo sticks that uses compressed gas and they use plastic .
JThiessen
JThiessen's Avatar
03.28.2008, 09:44 PM
Ceramic has no friction when rubbed togeather, does not expand when heated, and can do unbelievable temps without changing it's properties. You could do a motor with no rings (tollerances of 1-2 microns), no oil, and let it run as hot as the fuel burns.
You are correct about the ceramic - but remember - there is a good reason ceramic is not widely used in automotive engines. Long term reliability is a significant factor with ceramic. Also, impregnation from oils and fuels can cause degredation over time - especially when combined with heat. And at 60K rpms, there WILL be significant heat.
You didnt perhaps work in the aerospace industry in Seattle for a time did you, Mr Smith? I used to work with a guy by your same name.
Good luck with this development. Regarding the patent, remember, the smallest details can make a huge difference in a patent.
Also, for prototyping, there are companies that offer rapid prototyping. The materials are usually a starch based plastic, some similar to epoxy resins (these are a bit more pricey). Not sure if that will apply to you, but it may be one option. I'd guess a complete shock would run you about 50 bucks to have made, 100 or so if you want to fabricat one that is slightly funtional. I am flying to Orlando in a month to the Rapid Prototyping National Conference - should be interesting.
lutach
lutach's Avatar
03.28.2008, 10:17 PM
DrKnow65,
Here are some materials to think about:
Sapphire, Sialon, Tungsten Carbide (The material I have a sample of), Tetragonal Zirconia Polycrystal (TZP) (Might be a good choice). You might also want to try and contact a few of the pioneers of super strong Nano Tube technology, I'm sure they would love to create something new.
