Hakan_J
03.29.2008, 05:31 AM
I'm not sure where you got your buggy and truggy from, but from the factory the Buggy comes with the 26/9 gears and the truggy comes with 38/11. Check your part numbers and manuals. The huge teeth you are talking about belong in the buggy and are mod1.5 pitch instead of the normal mod1 pitch gears.
Matrix Arena comes with MXS38 Steel Ring Bevel Gear-T38xM1
Matrix Buggy comes with MX040 Ring Bevel Gear d6(26T)
I have both as well and actually moved the CEN truggy difs (38/11) to the buggy and put the HB 43/10 gears in the truggy. That gives them both "normal" (or very close to it) gear ratios.
I have noticed that the Factory Pro version of the buggy has different Bevel gears than the RTR version!
Edit:
Could be the source for this confusion....
AE RC 8FT
KO Propo EX 10 Helios
Tekno NEU 1515 1Y
Mamba Monster
TrueRC 4s 8000 Mah
Shark413
Shark413's Avatar
03.31.2008, 01:14 AM
Update:
Girlfriend had to work Friday night so I had some extra time to work on the truggy. I made up servo mounts and a motor brace. I originally made motor braces to keep my Feigao endbells on. The Neu motors don't need them for that, but having the motor hanging by just two screws and putting a lot of leverage on the area were it mounts to the chassis, the brace really triangulates the brace and makes the mount rock solid. I also swapped out the 26/9 diff gears with 38/11 to give me a lower gear ratio. On the original Cen truggy the center diff mount has spacers to help it to clear the huge spur gear. On my conversion, since I was using a much smaller 46T spur, I just added spacers so the chassis braces would sit in there orignal positions.
The original CEN truggy had huge ring gears 26/9T (left) I swapped them out.
Here is the ferriswheel CEN spur next to the Kyosho 46T plastic spur.
Here are the center chassis brace spacers.
Motor brace
Brake and steering servos and mounts.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
Shark413
Shark413's Avatar
03.31.2008, 01:18 AM
Update:
Saturday night I put the finishing touches on the truggy. Finished the battery tray, rx mount, hooked up brake linkage, added the ESC, added UBEC, added antenna mount and put everything together.
Top view showing the finished truggy.
Shot with the body on.
Shark413
Shark413's Avatar
03.31.2008, 01:24 AM
Update:
Sunday morning off to the track for some testing.
Cen brushless truggy next to my Kyosho ST-RR.
jhautz
jhautz's Avatar
03.31.2008, 08:57 AM
Looks great!. Let us know how it runs. I love mine.
to make it...
or break it...
Silent...But Deadly
Shark413
Shark413's Avatar
03.31.2008, 02:38 PM
Well bad news regarding the track test. My local track has a big table top followed by a big double jump. Normally you land on the back side of the table top and then take the double jump. The truggy was running great for 4 or 5 laps, but then I gave it a little too much throttle and I pancaked my landing into the face of the double jump. The truggy started to make some bad sounds so I came in to take a look. What I found was that the hard landing and subsequent stress it put on the drivetrain had knocked two teeth off the plastic spur. So now I am looking at ways to prevent this from happening, obviously landing under full throttle is bad but it happens once in a while, what I want to do is make the drivetrain a little more durable. I figured I have two options, 1) use a hardened pinion and steel spur. This would be the easiest solution since I wouldn't have to modify anything, but the drawback is drivetrain stress will still be passed to the other parts, so instead of a spur stripping now a diff gear will break or something in the motor will give. Option 2) would be to add a clutch or slipper, right now I could get a Tekno clutch. This would provide some give (slip) and smooth out the power. The draw back is I would have to modify my current setup to make room for the clutch. A slipper differential would also be great but I have not seen one in production yet.
jhautz, sounds like you have a lot of experience with both items (clutch and steel gears) any suggestions?
Shark413
Shark413's Avatar
03.31.2008, 11:27 PM
I am leaning towards the Tekno clutch. I mocked up the clutch and bell and it fit pretty good. I just need to move the motor mount back about 10mm and raise the diff to get a little more bell clearence. I can easily raise the diff by moving the spacers from the top to under the diff mounts. I will have to drill new holes to move the motor mount back.
I turned down a Traxxas flywheel to match the bell diameter.
If I raise the diff the cutout in the diff mount will match up with the bell and allow a little more clearence. I will also countersink the motor screws for more clearence as well.
