Go Back   RC-Monster Forums > Support Forums > General Nitro
crazyjr
crazyjr's Avatar
04.01.2008, 02:04 PM
actually the size needed is not the 32 pitch tooth count, The 52 tooth MGT gear is about the same size, but not sure of the offset and position to the bell
04.03.2008, 12:54 AM
t-maxx 3.3 or original? the original accepts monster gt spur gears no problem, however, you cut the crank on a t-maxx motor and it won't accept mod1 clutches. What pitch is a revo? I believe mod .8 or 32 pitch, and anyway, a 16 tooth clutch with a 52 tooth spur is about the same as a 20 tooth clutch and a 72 tooth spur(standard t-maxx ratio)
04.03.2008, 01:01 AM
edit- if the revo is mod1 then everything will work, I'm unsure of the pitch though, a 52t mgt spur WILL bolt right up you just need around a 16 tooth clutchbell, can anyone chime in with the revo gear pitch?
04.03.2008, 01:31 AM
revo is mod1
04.03.2008, 04:13 AM
Linc- once again, you da man
Lafayette- it'll all work
