fore106
04.01.2008, 11:13 PM
I did a little more work tonight. I tore down the roller chassis a little more to get it nice and clean. I got the feigao 7xl in the mail today so I decided to
do a little mock up with the motor and tekno conversion hardware. It was pretty easy and I can wait to finish and get this thing on the road.
I just realized i ordered the wrong size heatsink and clamp from RCMonster......o well...I hope I can exchange it.
The only issue is needing to dremel a flat spot on the on the motor shaft for the elektri-clutch adapter.......no problem there.
So far so good.....just waiting on a few more parts and the lipo battery. Im going to use a hitec hs-645 high torque servo.
Im most likely going to get it going before installing the center dif and forward only......just to see the difference.
Also not sure what im going to do for gearing.....any suggestions?
I do have a few questions.
1. The wires on the MM esc.....red...white...black. The wires on the 7xl Red...Green...Yellow. What goes to What??
2. The Tekno instructions suggest installing the clutch shoe's in the leading position. Anyone have an issue with this?
kingiggy262
BL-Revo
04.01.2008, 11:29 PM
The colors on the motor wires don't matter just plug them in and see if it runs correctly and if not then unplug and switch two of the wires and it should work. This caused no harm when I did this to my MM setup so you should be fine.
Mine ended up being:
MM->Feigao
RED->YELLOW
WHITE->GREEN
BLACK->RED
azjc
04.02.2008, 02:48 AM
with my Revo I have done the FOC and the CD as you have but also it really helps to do the Mod that involves removing the 1st gear and locking in the 2nd gear (with as much instant torque you get with a BL motor 1st gear is unneeded), I have read that you should use 500k fluid in the CD ( it come with 100k) but I have yet to test this for myself and also I am a basher not a racer so it is to be seen if it matters.
here is the link for the Mod
http://rc-monster.com/forum/showthread.php?t=7441
and I went with the 3rd option and using motor braking, I was thinking since I am not racing the braking won't be a major issue
fore106
04.02.2008, 05:40 PM
AZJC......I have looked at the "2nd gear only" mod. I think im gonna leave the trans stock at first...then do the FOC and center diff.....then maybe lock out first...then close gear ratio....
I will do one mod at a time and see how it effects the truck
Im still not sure what clutch bell/slipper combo to go with.
