azjc
04.02.2008, 12:05 PM
Originally Posted by xcntrk View Post
Doesn’t the latest castle-link software only allow a max of 12v for cutoff (4s 14.8v)? I don’t see in the menu where you’d specify a 15v cutoff. Maybe if you totally disable the internal LVC and run an external one it may sync up. Easy way to try is to “disable” the LVC and plug in the 5s pack to see if it engages (obviously you cant run the 5s pack without LVC protection).
the MM has a "custom" setting for the LVC, I have my 4 cell set @ 13.2v
jhautz
jhautz's Avatar
04.02.2008, 03:26 PM
Yea custom setting is great. I set mine at 15V and run 5s on an older style MM
to make it...
or break it...
Silent...But Deadly
raptor50
04.04.2008, 12:57 AM
My Jazz or Neu coggs big time after stop and go.. I had Nemesis motor 7xl w/ MM and that thing worked flawlessly. MM barely got hot and the motor was warm to the touch but not hot. MM and Nemesis was about 1/3 the cost of this Jazz and Neu combo.
I think I got the right motor, Neu 1515 2.5 but WHAT ESC? HELP ME!!!!!!!!
I spent about $900 bucks and nothing works. thanks..
lutach
lutach's Avatar
04.04.2008, 01:20 AM
You are using the BEC right? Did you remove the RED wire from he controllers receiver plug? I had to do that with my Beat and Smile. I also had an issue like that with a BK 7018, but it went away after I disabled the BEC (Jumper on the BK).
