04.04.2008, 10:32 AM
Originally Posted by flipmac View Post
Those are some sweet lookin' battery trays and your conversion is very clean, lincpimp. I also converted a Hyper 7; check mine out.
Looks good, nice conversion!
Originally Posted by xcntrk View Post
Subscribe: I too have a Hyper-7 to convert! Watching this build closely. Still looking for finished pics showing your servo configuration. Why wouldn’t the stock servo plate work again? Do the RCP trays interfere with the stock mounting?
The RCP trays take up 1 hole that the stock standoff mounts to. Look at the pic on the rcp site and you will see what the servo mount needs to look like.
04.05.2008, 12:37 AM
Ok, snagged a pinion for this project to gear it down a bit. Only dropping 1 tooth, but that should be perfect. I will have to remove the mount, and make the slots slightly longer so that I can ge the smaller pinion to mesh correctly.
