azjc
04.05.2008, 11:00 PM
Originally Posted by Superbasher View Post
I've had the same problem. I don't think it is a fault with the ESC, but more of a fault of where they put it, as the wires stick up further than the shock tower, meaning that if you land a jump upside down they break, which mine did. I managed to fix it by soldering the connector back on the PCB, but i'm on the hunt for a cheap MM ESC.
I agree with you that the location of the ESC is bad, I have since located my MM and BEC on the lower chassis opposite of the RX using velco to secure
Superbasher
Superbasher's Avatar
04.06.2008, 05:52 AM
I tried that with the VXL ESC, but the lead is too short to feed it over to the receiver, so i've mounted in the original position, but sideways (so the bottom of the ESC rests against the shock tower) so it isn't in the firing line now.
  Send a message via MSN to Superbasher
