kulangflow
Never Fast Enough
kulangflow's Avatar
04.07.2008, 11:25 PM
If I only count the first 100 mAh and include the fact that the max voltage of the pack at the beginning is 18.1V (as opposed the theoretical 18.5V I used initially), then the numbers look a little better:
10C - 46A - 15.6V - 3.2V / cell
15C - 69A - 15.0V - 3.1V / cell
20C - 92A - 14.0V - 2.9V / cell
25C - 115A - 13.0V - 2.7V / cell
Do they usually factor in the whole run? If you're averaging in the low voltage at the end of a run, it's going to drop everything, right?
