Cartwheels
05.23.2008, 11:52 PM
Mike needs a link to the store on the header some where so we could access the store so much more quickly. It would also help newbies find his store quicker.
Mofomaxx
05.24.2008, 05:05 AM
Thanks, i had actually found that already but was unsure if it was just for the 8eight or the 8eight T aswell.....
What about battery mounts etc ? i assume the generic one in mikes store will do, but i can't find much info on the whole setup, i.e. what mods are needed to the radio tray, how to mount the battery on the 8T chassis, which spur gear etc......
I found the rc product designs www & they seem to do a whole kit, but it doesn't look as neat as mikes motor mount...... any advice welcomed,
Andy
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.24.2008, 05:25 AM
I got one on the bottom of my page saying RC-Monster Store
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
05.24.2008, 09:43 AM
There are a few store links throughout the forums, actually. Should be easy enough to add more. :)
MoFo - the 8 mounts work for the buggy and the truggy. Our battery trays are kits, and we offer a couple sizes to fit whichever battery you have or plan to use. You should be able to find plenty of pictures for the mods, but basically you cut the radio tray behind the steering servo. The battery box box mounting is described in the listing as well. With one of our hardened pinions, you simply use the stock spur gear. :)
Mofomaxx
05.24.2008, 10:18 AM
Cheers mike, i have emailed you with same question & requst for a total price including p&p to the UK, before you posted this reply, i'd figured i'd need the motor mount, battery holder & pinion, just was unsure what else apart from obvious motor/esc was required......
I'd like to run a Neu motor, and probably the MMM, so im open to battery advice, i assume im looking at a high capacity 4s ? for nitro like speed & good runtimes ?
jnev
jnev's Avatar
05.24.2008, 12:41 PM
That is correct. Try to pick up a 4s Flightpower, Neu Energy or Polyquest lipo. You can also get any one of these three from Mike's store. Here is a direct link to the batteries:
http://www.rc-monster.com/batteries.php
