kingiggy262
BL-Revo
04.11.2008, 01:02 AM
Originally Posted by Revracer View Post
so does anyone know when this thign will really be out? i got a brushless revo sitting here waiting for a good esc. im about to just get a mamba max since i am only running 3s... but it is on a 6pole...
Just to let you know the MM and the MMM will be using the same firmware v1.17 so if you are only using 3s and don't need to pull 110+ amps then the MM will work just as well on your 6 pole motor as the MMM because the firmware is not different.
blueb8llz
04.11.2008, 02:11 AM
im going to run on only 4s with a 7xl, but im still choosing the mmm because if i was to get the mm, i will still need the fan and the cc bec which will add up to just about 30-50 bux cheaper than a mmm. and with the mm i will sorta have to worry about heat issues esp. when summer comes around whereas with the mmm for 50bux more, i wont have to worry bout a thing. and if i ever do decide to run on 6s, i will have the option there for me.
i dunno ...this is just me i think its worth the wait. ive been wanting to go bl on my 3905 since i got the truck which is only like 2 months ago, and i almost just went with the mm, but now that the mmm is sooo close, imma waitin.
