Thunderbruiser
Thunderbruiser's Avatar
04.11.2008, 02:53 PM
well i'd rather use 5s or 6s if i could because im just that greedy however i wanna make sure the esc could handle it ya know...also if i run 5s/6s do i need to run an rx pack and disable the internal bec?
i'd rather run this because it's spec'd higher and that way i'd have a mamba for the rustler...and 1 mamba left that i have to have fixed...
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
04.11.2008, 03:04 PM
Yep, disable the internal bec and run a ccbec, or receiver pack. Some have issues with fully charged 6s packs making the esc "freak out" until the voltage drops slightly. I did not notice this with my 6s buggy. I would not gear too high either, 40mph sounds good to me and I gear mostly everything to that speed.
jhautz
jhautz's Avatar
04.11.2008, 03:08 PM
I ran a Quark 80B on 5s in a 1/8 buggy and pushed it over 60mph. The little quarkk actually held up fine. If you gear it down a bit in the truggy I bet that 80B might surprise you. Just make sure you have it mounted flat to the aluminum chassis to act as a heat sink or attach some sort of heat sink and fan to it.
to make it...
or break it...
Silent...But Deadly
