speedracer1129
04.11.2008, 04:25 PM
Originally Posted by tom255 View Post
Unfortunatly I dont have radar and GPS I hoped that RPM sensor is accurate.
so Brian as I understand I need calibrate it?
I try figure out proper RPM using Prop Tacho, My friend have it...
Buy now I charging my battery and will try out it on load. Lets look what amps is going through maybe i will figure out why my 9XL run so hot? Outside is now perfect day for test Dry and Cold :) only 43F
tom,
the car profile is a little screwy! i have been working with Don at ET on this. Make sure you go online and download the latest software and firmware. Also, use the airplane profile as it seems to be more accurate at this time.
