aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.12.2008, 09:21 AM
Peter, are you positive?.. because LMT said the Hi-Amps were different and was able to deliver more power than the regular 2280s, the stators and rotor are different as well... http://www.lehner-motoren.com/motordaten/Motordaten%202280/2280-5.HA32V.xls
Those datas from LMT were the only reason I purchased this motor back then... because back then, I knew that they will finally have something like the 40.300 out...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Peter Zicha
Peter Zicha's Avatar
04.12.2008, 11:21 AM
this topic was brought up on rumrunners forum , these guys have both but apparently the only difference between the two is the rear endbell
http://www.rumrunnerracing.com/fefor...ehner+high+amp
GriffinRU
04.13.2008, 11:21 AM
Sorry for your LMT loss and hopefully U will get it back in no time.
I do like them both Neu and LMT but I will agree that in terms of balancing Lehners are on the shy side, while none of them will match quality of pletts, just from observation and testing.
Interesting fellows on the boats forum, maybe I should mod couple ESC's for them :)
But, so far nothing then end-bell from this link.
Extra charge for proper, cheaper, simpler end-bell doesn't sounds like German.
What I've read some time ago (and cannot find it anymore, even on the LMT-site they now referring to end-bell difference only!?) that wire gauge was different as well...
Peter Zicha
04.13.2008, 04:19 PM
Griffin....mod them as in how.............................................
I agree with you said about the pletts , there quality is second to none , I have 3 brushless pletts and three brushed all ( 355's )
GriffinRU
04.13.2008, 04:40 PM
With water cooling on-demand you can draw ridiculous amount of Amps with smart layout. All the same more Amps, better cooling.
-I do love brushed 355-series, two of them were placed in my neighbors barbi-jeep you can imagine what a joy it was in conjunction with optima battery :)
Peter Zicha
04.13.2008, 05:50 PM
Something like this , I have a lathe and a CNC mill , I mod all my own and also swap the battery cables out to 8awg
Being a plett fan you should enjoy this 355/50/06 and mini berkley jet drive
ID:	4409   Click image for larger version
ID:	4410   Click image for larger version
GriffinRU
04.13.2008, 06:04 PM
Sweet!!!
othello
HV basher
04.12.2008, 11:56 AM
Having red a comparision (in german) between a Neu 1515 (340/360gr) and a lehner 1950 (355gr) stating there is no big difference in Power output (only different efficiency points) i think it's fair to compare a Lehner 2280 and a Neu 1527 looking at their wheight.
Wheightwise a Neu 1527 is more comparable with a lehner 2250. A Lehner 2280 wheighs 200-250gr more then a Neu 1527. It is also longer and has a bigger diameter. I think this allone should be sufficient to tell which motor can handle more power since both do claim efficiencies around 90% and both do only cook with water (or should i say copper ...).
BTW windings of the Neu motors do come from Mexico.
There is a good write up (in german though) on Neu Motors (with pictures and diagrams) with a comparision of a Neu 1515 and a Lehner 1950 on this site. By using babelfish you could translate this website.
Peter Zicha
04.12.2008, 01:27 PM
Very interesting write up....thanks for posting it
