trani repaired!
plettenbergs
plettenbergs's Avatar
trani repaired! - 04.12.2008, 11:26 AM
....no damage...the small hollow pins that hold the drive gears to the shaft sheared off!...thank goodness i also located the two small pieces inside the trani case...they were stuck to the sides...in tact and not smooshed flat by runing through the gears!...i will be switching to lipo this week before i blow out something big$$$!...i can shave almost 2 pounds right there,if it still is too heavy i will drop a motor!
I am sure i can find a new ride for a BIGmaxximum and a Schulze 18.97!
i still need an exact part number for the exact LIPO batts to purchase,please?
i will be gettind the Hyperion duo charger!
Thanks
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Thanks - 04.12.2008, 12:03 PM
Thank you for sharing your experiences wtih this setup. I am learning from your issues, and I have a Big Maximum and a Schulze 18/97 (2nd hand)arriviing very soon for my UE SuperMaxx. I am only planning to run one motor and I do believe that it will do just fine as a single. I want power and speed, but I am not looking to break any records. I just want to have fun, and I still believe that it will turn heads. My challenges will be getting the right gearing and battery setup to keep it runing strong and efficiently as possible. I will probably start with 3S 10K mah, and work my way up from there. I have a few Maxamps packs already, but I think I will try some of the other more potent brands for the increased "C" ratings. Your thread has given me a lot to think about. Thanks Man.
i got my CA$H for lipo READY!
plettenbergs
i got my CA$H for lipo READY! - 04.26.2008, 11:50 PM
Polyquest 16/25,PQ5350LP-4s or 5s...what to get?...any final input?
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.27.2008, 12:10 AM
you're still going to run 2x BigMaxx right.... go for 5S...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
