83gt
04.14.2008, 02:34 PM
Originally Posted by Topspeedtimmy View Post
It's not nearly that simple, the on/off circuit is already connected outside the ESC but it is disconnected somewhere else in there. I guess i'll just crack it open and take a look.
I don't really see how that is possible. Are you saying you burnt a trace inside the ESC ? I think it is likely something else is wrong. There is really no way to pull those traces out, unless you can see the damage where the wires solder in on the front of the ESC.
You said you "connected" the "on/off circuit" by twising the wires. Just de-solder the wires where they connect to the PCB, and solder the two points together. I would not count on the wires to be in good condition after you drug the switch along the ground. One of them might be broken inside the insulation.
J.
Topspeedtimmy
trick mad power (tmp)
Topspeedtimmy's Avatar
04.17.2008, 05:35 PM
Maybe I wasn't clear enough. I took the switch off long before the crash and the wires were cut to a half inch, stripped, and twisted together. I soldered the wires together just now to make it a little more secure, but it obviously didn't make it start working. The problem is probably far worse than I could have imagined , so I'll send it in to CC for repairs.
