04.16.2008, 09:49 AM
Duster - Many thanks for the info. I bought a pair of flm 7075 diff cups from Mike last night, so I will give them a try. I will also shim the diffs in the stock cases and see how they do.
Jerry - I know, go big or stay home! If I do buy the hybrid bulks, they will go on the flm tranny forward, as I am running cen genesis wheels/tires and those things are heavy! I am sure that the stock diff housings will not hold up to that!
I am using this savage to figure out the strong and weak points so that I can upgrade the other savage. The other truck will be heavier, so it needs strong parts!
BOOGIE444
04.16.2008, 11:13 AM
In my experience with my big and heavy extended savage aluminum diff cups, with shims and 4 gear diff takes care of the problem. My savage wouldnt handle my axial .32 I ran in it for two years without the upgrades.
I now have been running my savage with a 7XL and 4s and sometimes 5s lipo and the diffs are holding up fine even with the slipper tighten all the way with a metal spur gear. In two years of racing and bashing I only blew the front diff out once with my setup, and that was because I had the throttle pegged and ran into a nasty wall at high speeds. Gotta let go of the throttle when your going to run your front wheel into something hard & fast
BOOGIE444
04.16.2008, 12:01 PM
I also recommend locking the tranny in second gear, it wont take long before you to break some tranny gears when that sudden power from a brushless motor slams the tranny when shifting from 1st to 2nd.
When the tranny is locked in second and the diffs are shimmed & aluminum diff cups the savage drivetrain is easily as strong as any buggy / truggy that I have used in my experience.
04.17.2008, 01:46 AM
after all the upgrades (alum. cups, diff housings and bulkheads, 4 spiders shimmed) i found the weak link to be the pinion shaft bearings, they went and I ended up shearing diffs, I haven't had that problem since I ran bocas on the pinion, its the only place I use spendy bearings, but so far they've held up to the o.s. .30
