04.17.2008, 08:50 PM
I read the whole post, now wheres my reward bitch?..
jhautz
jhautz's Avatar
04.17.2008, 09:39 PM
He is using a 45mm diameter motor.
check...
to make it...
or break it...
Silent...But Deadly
MetalMan
MetalMan's Avatar
04.18.2008, 12:59 AM
How about some sort of "idler" gear between the pinion and spur? Might help solve motor fitment issues without having to gear so tall. Don't know if it's feasible...
That's something I hadn't thought of. TBH, if I went with an idler I think I would just throw a slipper clutch in there as well and call it a day - but then I'd still need that 20t pinion anyways . One idea I had was to drop in some truggy diffs, with their lower ratio of 4.3:1. With an 18t pinion and 10s A123, that'd put the top speed at a much more respectable ~54mph, which is still way too fast for typical bashing.
I need to see a picture of this setp... I am trying to figure out why the motor would hit the outdrive with less that 46/20...
I have seen 46/12 run on buggies and truggies without hitting the dif outdrive. Why is this different?
Like linc said, it's a 45mm motor. This was a tough shot to take (and because I was too lazy to remove the chassis brace):
I could definitely get away with an 18t pinion, but I dunno about anything lower.
MetalMan
MetalMan's Avatar
04.18.2008, 01:00 AM
Yes, master.
Please excuse the horrendous wiring. Two servos + PiStix + long-ass ESC-RX wire + series battery connectors + tight space.
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.18.2008, 01:46 AM
I'm ready, though half scared, to see this thing in action. The last time I saw it (which was the first time) it really gave me a numbing feeling seeing something that big and heavy going THAT fast.
04.18.2008, 08:01 AM
I bet. It doesnt look like a savage anymore, when you see it from the side- lowered so much it looks competely different. Those shocks are huge....
04.18.2008, 09:48 AM
Looks good Metalman!
Any reason that using a larger spur gear would not work? IIRC there are some 48-50t metal spurs available that should fit the std diff cup. I am sure that ofna make a few different sizes. Then you could step down on the pinion size and still have adequate clearance.
MetalMan
MetalMan's Avatar
04.19.2008, 01:50 AM
If you look at the pic in post #18, you'll see where the 46t steel spur currently sits. It's pretty much as low as it can go, so any larger spur wouldn't fit properly.
04.19.2008, 11:53 AM
Yeah, that is what I thought. But I figured that I would throw it out there...
jzemaxx
04.19.2008, 04:49 PM
What radio system are you using with your setup?? Any glitching problems?
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
MetalMan
MetalMan's Avatar
04.20.2008, 12:21 AM
Nomadio React, I kinda need all of its adjustments for this Savage, because I like to be technical . I also use this radio for all of my other trucks/buggies. No glitching problems for it as far as I have seen.
Brushless-truck
04.20.2008, 06:24 AM
WOW!
thats such a nice savage
Last edited by Brushless-truck; 04.20.2008 at 06:25 AM. Reason: missed out nice :p
MetalMan
MetalMan's Avatar
04.20.2008, 08:25 PM
Thanks!
MetalMan
MetalMan's Avatar
09.04.2008, 01:50 AM
Time for an update!
Within the past 4 months this truck received one of the Hobby City KD-36 XL 1200 kv motors. It did alright, but fried on Monday. And I mean fried, as in was SMOKING and temp'd at 350 degrees... Cause of death appears to be a short at the exit wires, although I can't say for sure.
Next up is a brake on the rear of the center diff. If you recall, I only had two discs on the front of the center diff. They overheated pretty badly... So with new rotors and pads in addition to the rear brake this truck stops pretty well for its size/weight.
Yesterday I threw my spare Feigao 12XL into the beast. And what a beast it was, until the run ended after only ~3mins. Turns out one of the A123 cells was at 155 deg. while the rest were about 95.
So I reconfigured the pack to 9s1p, and WOW, what a huge difference that bad cell made. Power is incredible, better than with that 10th cell there. And it's fast too, about 50mph. If the center diff didn't unload so badly I swear this thing would flip itself over.
One final comment: I LOVE THE HV-110. As an airplane controller it performs flawlessly in my Savage. Cogging is EXTREMELY minimal, and very low-speed driveability is amazing. The best part: it doesn't seem to heat up past 120 deg. Granted my run time isn't all that great with only 9s1p geared for 50mph, but it sure is fun!
Semi Pro
Semi Pro's Avatar
09.04.2008, 08:10 PM
Time for an update!
yep i love mine too, i havent gotten it over 100deg even after 15 min of racing, i only got the hv110 because of all the mmm problems and i must say it was worth every penny
and when you take the body off peoples jaws drop
