4s 8xl rustler, gearing???? -
04.18.2008, 05:32 PM
What speed should I gear my 4s 8xl rustler for? what amp rating battery will I need?
04.18.2008, 05:34 PM
299 792 458 m / s
04.18.2008, 05:38 PM
Soldermaster Extraordinaire
04.18.2008, 07:15 PM
Seriously, how fast do you WANT to gear it for???
I'd go for a battery with a solid 100A continuous rating.
Brushless Heavy Weight....
04.18.2008, 07:21 PM
Yeah, a 3700 25C Lipo would do good...
what about 24/51 gearing... that's what I was using with a 7XL on 4S....
04.18.2008, 09:54 PM
I've a mod1 46 tooth spur, biggest that can fit
04.19.2008, 03:35 AM
What kind of spur is it? The biggest I found to mate with that slipper is the 40t revo gear. That said I haven't looked further than my spares box :P I did a quick search on tower and all the other spurs for that slipper and 32p for the jato and tmaxx...
04.19.2008, 05:35 PM
monster gt 46 tooth spur, just barely clears driveshafts
04.18.2008, 10:21 PM
My buddy just put his VXL stampede back together with a 7XL and BK9920 or 5S. He hasn't drove it yet, but we have no idea what gearing to put on it. He wants 70+ is all he said....
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
04.18.2008, 10:30 PM
man..7XL is just crazy power for them small 10th scales... an L motor can take them to 70MPH... why don't you guys use the BrianG super calculator..
04.18.2008, 10:37 PM
4s 3700 sounds good. You could go bigger to a fp 4900 4s. Weight should not be an issue with an 8xl.
I would put a 40t revo spur on and use an 18t mod1 pinion. That will get you to about 60mph with stock height tires. Sounds like fun!
04.19.2008, 02:42 AM
thats a lot of motor for a Rustler, I have a 9L in my Rustler with a True RC 15c 4s 5000mah lipo. Geared with a jato 54 tooth spur and a 15 tooth 32 pitch pinion and that has all the power you need, anymore and it would be too out of control
Yip Yip Yip...
04.21.2008, 07:55 AM
We setup my friends stampede with a 9l on 3s and it has all the power it needs. 4s would be crazy.
04.21.2008, 10:37 AM
[QUOTE=MTBikerTim;164880]We setup my friends stampede with a 9l on 3s and it has all the power it needs. 4s would be crazy.[/QUOTE
I will say its borderline crazy....  , you need to have a lot of control with the throttle, you cant go WOT from the start, you need to have the truck rolling before you go WOT, I have had some nice cat walks, I have put some fishing weights in the nose and that has helped in keeping the nose down and make the Rustler a bit more stable
04.21.2008, 02:17 PM
Is there any kind of mod that needs doing to fit the monster gt spur on? I'm assuming your using the 3 bolt style revo slipper on the rustler...
Its a direct fit on the old style slipper, which is what I use. With slight modding (drilling out some holes) it can be used on a revo spec slipper
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
