bdebde
That's All Folks!
bdebde's Avatar
04.18.2008, 05:55 PM
Is this at low speed or at all speeds? I have same controller, and it will do the instant reverse at low speeds, but the brakes work at higher speeds. Try it in forward only and see if brakes work.
TDC57
TDC57's Avatar
04.18.2008, 06:05 PM
Hay bdebde!. it does it at all speeds.
forward works great at any speed (rev-up-down) no issues. when I apply the brakes "anytime" it instantly goes in reverse?? Once it's in reverse I can speed it up and down! And then I can back to forward..
Just no braking?? And I need brakes!..
What about the rest of setting?? any thoughts on what i should change and or adjustments??
Thank you for your time..
Shaun.
Nothing!.. Hahahahaaa..
