azjc
04.19.2008, 02:42 AM
What speed should I gear my 4s 8xl rustler for? what amp rating battery will I need?
thats a lot of motor for a Rustler, I have a 9L in my Rustler with a True RC 15c 4s 5000mah lipo. Geared with a jato 54 tooth spur and a 15 tooth 32 pitch pinion and that has all the power you need, anymore and it would be too out of control
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
04.21.2008, 07:55 AM
We setup my friends stampede with a 9l on 3s and it has all the power it needs. 4s would be crazy.
azjc
04.21.2008, 10:37 AM
[QUOTE=MTBikerTim;164880]We setup my friends stampede with a 9l on 3s and it has all the power it needs. 4s would be crazy.[/QUOTE
I will say its borderline crazy...., you need to have a lot of control with the throttle, you cant go WOT from the start, you need to have the truck rolling before you go WOT, I have had some nice cat walks, I have put some fishing weights in the nose and that has helped in keeping the nose down and make the Rustler a bit more stable
04.21.2008, 02:17 PM
Is there any kind of mod that needs doing to fit the monster gt spur on? I'm assuming your using the 3 bolt style revo slipper on the rustler...
Its a direct fit on the old style slipper, which is what I use. With slight modding (drilling out some holes) it can be used on a revo spec slipper
