bdebde
That's All Folks!
bdebde's Avatar
04.21.2008, 10:43 PM
Don't breath on those MA packs... they may puff!
04.21.2008, 10:52 PM
Oh no, I was pushing them hard. 82 amp rated pack trying to turn a novak hv6.5 motor in a crt.5. That is a heavy truck, and geared for 40mph. Way too much load for a 82amp rated pack. I think I need and 8000 3s maxcraps pack, maybe 160amps would be enough for this beast...
sikeston34m
sikeston34m's Avatar
04.21.2008, 11:46 PM
160 amps is just the Continous Rating. Those 8000mah packs are good for a 400 amp Burst Rating.
It says so on the website! *rolling eyes*
04.22.2008, 01:26 AM
Only 400 amps, the crt.5 can easily pull that. I think that maxamps are underestimating their cells a bit. 400 amps at 11.1v is about 6hp. A trx 3.3 can make that easy...
VintageMA
VintageMA's Avatar
04.27.2008, 09:25 PM
Well.... here's my very techincal prrof of concept on MaxAmps vs. Neu cells.
I've been running a 4S 5000mAh MaxAmps in my XB8EC and got a 5S 3900mAh Neu pack in preparation for the MMM.
Though I would try out the 5S pack in the MM to see how it would work or i I would send the MM up in smoke. Needless to say it works fine and temp were no higher than 130* (w/ ccbec, fan and no extra caps).
I had lowered the gearing on the XB8 from 17/48 to 15/48 in preparation for the new pack and with the Maxamps 4S 5Ah pack I was getting about 10 minutes before the pack would dump (pack less than 3 months and 10 cycles).
I ran it today with the Neu pack and WOW unbelievable. I ran the car VERY HARD for 15 minutes and the pack hadn't even dumped yet. First time I ever saw a 1/8 buggy pull a full wheelie .
Anyway - you would think with same gearing a buggy on 5S would pull more Amps and last last time with a lower rated pack than on 4S, but the 5S pack only pulled 3.355Ah during the run and took 3470mA back in the charge.
This is compared to the MaxAmps 5K pack dumping around ~3.5Ah in a run and taking back over 4 during charge.
Needless to say - MaxAmps are going up on e-bay after this experience.
“Everyone has a right to be stupid; some people just abuse the privilege.”
gixxer
gixxer's Avatar
04.27.2008, 09:30 PM
I have a maxamps 6000mah 5s pack and after I bought my polyquest it just doesn't get used anymore. I want to get rid of it since it will probably never be used again but really how much do you ask for a crappy pack?
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
VintageMA
VintageMA's Avatar
04.27.2008, 09:48 PM
I've put plenty of Maxamps pack up on ebay - post it for a low pasting fee (like around $15) for 1 week and by the time it sells you will probably make at least $100 on the pack.
04.27.2008, 10:55 PM
Most people on ebay think maxamps are gold. That is due to their overzealous advertising. Good for you! Just start it at 1 dollar and let it go, you will get a price for it!
