mriccucci
mriccucci's Avatar
04.24.2008, 06:25 PM
its me or mricucci- any progress? I've been watching!
I've also been busy, im deffinatly not very good with the jigsaw and dremal but i think i may be able to get a local guy to laser cut another chassis plate.
My plan is to make some plates to go from the braces to the bulkheads like its me did. I think i may extend them a little on each side. Im going to cut the chassis dont a lot more, prolly about 5-7 inches wide. I've got 14.5 inches of wheel base so im just about at the truggy lenght. The only thing i need now is to find a body that would fit.
04.24.2008, 09:06 PM
looking good
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
04.25.2008, 03:17 AM
would any one happen to know the foot print of the MMM???
rccna.com
04.25.2008, 05:18 AM
2.2"x1.9"
its me
its me's Avatar
04.25.2008, 02:45 PM
2.2"x1.9"
Thanks man!! I can start on the speed control trays now!
rccna.com
04.25.2008, 03:43 PM
I didn't feel like reading through the thread and don't know if this has been mentioned yet. You are going to want to run the batteries and esc's in parallel, so they see the exact same voltage. It will also require pulling the red bec wire from one esc reciever connection, so only one esc feeds the reciever power. Might wanna make the front top plate bigger to hold a steering servo. If you knew all this nevermind, I just want to see it run!
its me
its me's Avatar
04.26.2008, 01:54 AM
Good info and thank you, I am a absolute noob when it come to electric. The steering servo will actually end up under the top plate, so that whole area is good to go for electronics only :)
rccna.com
SnoopMaxx
SnoopMaxx's Avatar
03.02.2009, 04:18 PM
This is one of the the single motor mount
Electric Motor Mount HB Stadium 10
And the twin motor mount is from an E-Maxx 3906
Traxxas Motor Plate E-Maxx
Traxxas Motor Plate Custom E-Maxx
Trinity Motor Mounting Plate E-Maxx
Morten SnoopMaxx
Never to old to play
c",)
Emaxx_Quebec
Emaxx_Quebec's Avatar
03.05.2009, 04:19 PM
With the agreement of “IT’S Me“ I post my step by step process to make this mod.
1: It will be cheaper if you have already:
- Center dog bone.
- 4 old and unused drive shafts. (replace 1/8 diff output shaft )
2: It cost me (include shipping cost to Canada):
- 2 x LST 2 diff = $43 us ( 43/13)
- 4 x 1/8 diff output shaft + 2 x Drive cup - 8mm bore for 1/8 diff = $50 us
- 1 Dog Bone center kit from Kershaw = $ 55
- Bow ½ pvc (Fem to Fem) + 1” join = $0.50
First, I cleaned the diffs and put Gorilla Swat in it and change the 4 diffs output.
When I put them back together and tighten the ring to the cup, it was impossible to turn the diff by hands.
I noticed that the RC monster output was a little bit too long so I had to shave them to the appropriate length. Once shaved the diffs output, it worked perfectly!!
Emaxx_Quebec
03.05.2009, 04:20 PM
Next, plastic trimming can get started. It’s better to do it slowly to not take too much material at a time. I used this dremel bit to do all the work.
I hope the pictures talk by themselves.
A lot of small adjustments is needed to achieve a perfect fit.
Emaxx_Quebec
03.05.2009, 04:21 PM
Then I had to shave the drive shafts a little bit too. After that, it was A LOT easier to install the pins.
finished with RCM 8mm Drive cup - Kershaw dog bone
I have a Ofne 51t mod1 spur 20t pinion with Bidpruduct 36/74 8xl 2075KV Motor with 43/13 diff ratio,
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.7222222222222223
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 20
Total Voltage: 14.8
Motor KV: 2083
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 83
Motor coil Ω: 0.0084
Spur/Pinion Ratio: 2.55 : 1
Total Ratio: 14.52628 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 29376.13 RPM
Vehicle Speed: 34.89 mph (56.05 km/h)
Effective KV Value: 1984.87
KT constant: 0.65 oz-in/A
Motor Torque: 0.28 ft-lbs
Final Torque: 4.08 ft-lbs
Final Power: 1228.4 watts (1.6 HP)
ps: I'm french speaking so my english is not perfect.
SnoopMaxx
SnoopMaxx's Avatar
03.05.2009, 06:46 PM
That looks very good I am definitely doing that when my stock 3906 diff gives up
Morten SnoopMaxx
c",)
