Bulletproof revo tranny?
azjc
04.27.2008, 11:08 PM
Originally Posted by
Trick440
Well good to here that it seems to get stronger with the FOC and diff.. I have them both ordered.
What else do you guys break, and should I consider upgrading? We mentioned the little pins on the gear shafts.....
How about the front and rear diffs?
this thread may help
http://www.rc-monster.com/forum/showthread.php?t=7441
azjc
2
Trick440
04.28.2008, 08:40 AM
For the Diffs, just the cups like these? And this will help prevent the larger 'ring gear' gear from breaking teeth?
Large ring gear...
Diff cup...
Thanks guys.
Trick440
Find all posts by Trick440
3
rschoi_75
Certified Spaceball
04.29.2008, 12:37 PM
Trick440
Large ring gear...
Diff cup...
Thanks guys.
As Brian mentioned, the cups will help the spider gears last longer. You still need to shim the pinion/ring gears.
On another note, you can use an alloy outer diff case as well, which will prolong the life of your ring/pinion gears:
rcm xt8
rcm xb8
rcm crt.5
rschoi_75
Find all posts by rschoi_75
4
bustitup
04.29.2008, 01:47 PM
I have read that if you take the innards out of the 16.8 volt emaxx diff. the fit right in the revo diff's and are much better
also the emaxx 3905 tranny is much stronger?....easy mod
bustitup
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
