Go Back   RC-Monster Forums > RC-Monster Area > Customer Testimonials and Feedback
04.28.2008, 12:29 AM
I have a MMM coming and plan to give it a try on 6s in my hyper st truggy. Will be spinning a 10xl for now as it was super cheap! I may step up to a 1515 2.5d if the 10xl does not work out.
I am interested to see how my 8s 14xl savage will compare to the 6s 10xl hyper truggy. I have had excellent success with the 8s setup, the 14xl does not get much over 150 in that truck, with hardly any airflow over it. Hope the 10xl will be as good. The hyper should be lighter when assembled than the savage, the battery is and the truck should be too.
It would be nice if the MMM will work on 8s, but then you will have to run an external bec, which is one of my favorite parts of the MMM. Imagine how neat the wiring wil look with the MMM!
VintageMA
VintageMA's Avatar
05.02.2008, 10:52 PM
Just a quick update on the results of this test:
Got a chance to run the CRT.5 with the TP2600 pak for the first time. It was kinda drizzling outside so was running a lot of wet grass so that gave a bit of rsistance, but I was very excited about the fact that with the left and right side of the buggy almost completely balanced within about 20 grams the buggy tracked prfectly straight accelerating and braking hard - no more pulling to the left or right because of a neavhy battery pack. With the lighter pack buggy weight was almost .25 lbs lighter - max Amp draw dropped to 53 Amps.
I think because of the think wet grass overall amp draw was up a bit so runtime was a bit shorter - only 9 minutes running very hard.
I'll have to try the exact same setup I did with the 4000mAh pack over the weekend and see what runtime is like.
“Everyone has a right to be stupid; some people just abuse the privilege.”
