johnrobholmes
johnrobholmes's Avatar
05.01.2008, 12:37 PM
Can't see them, I have been IP banned from your site unfortunately.
Did you collect any temp data?
---JRH---
austinelse
05.01.2008, 12:45 PM
Oh yes. There is that little issue:)
The temps were all between 85-90 degrees at the end of the discharge. Keep in mind that this is without shrink wrap on the cells so the temps would be higher in a pack format but no where near the 140 degree max.
I will try and get the high def versions of these posted here also so you don't have to squint.
I will also see about taking care of your banned IP issue:)
