PlayerOne
05.02.2008, 07:51 PM
Thanks
What battery should i get and what about two?
What ESC or is the Castle Mamba Monster an ESC?
So the Tekno conversion is good
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.02.2008, 11:29 PM
Originally Posted by PlayerOne View Post
Thanks
Battery really depends on budget. You got 2S (7.4V) 3S (11.1V) 4S (14.8V) etc. etc. Good battery will be 4S 5000 but then you got to measure what battery tray you will be using to see if it will fit the way you like. If you run a 4S battery you will only require 1 but if you were to use a 2S you will more than likely require 2.
Yes the Castle Mamba Monster is a ESC - http://www.castlecreations.com/produ...a_monster.html
Here is the link to RC-Monster Motor Mount - http://www.rc-monster.com/proddetail...d=RCMrevomount You can buy parts from the Tekno kit by themselves if you wanted to do a custom setup http://www.teknorc.com/product_info....roducts_id=940
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
