05.03.2008, 11:07 PM
Originally Posted by mk351e View Post
should have mentioned that I WILL be using mechanical brakes for this setup, not the motor. My only reason for wanting to use the clutch is simply to take the stress of shock from a landing off the motor, nothing else really. I do agree with everything said so far about the clutch adding stress to the system b/c of weight, etc., but what about the shock to the driveline during a landing?? Can't be good for the motor, no?
This is why a slipper would be nice, can't wait for mike's slipperential to come out. I want one for my hyper st, as I really want to race that truck!
Billetboy
05.04.2008, 10:20 AM
The elimination of cogging has probably already been covered here. But I also found another advantage on my Losi Truggy. The "direct drive" spur/pinion made my 1515/1y run hotter probably due to the load on the motor to get the larger truggys moving from a dead stop. With the clutch, you can get the rpm up on the motor before it is "loaded" up. On a side note, I put a really small outrunner( that had no business being in there) in my 8ight-T, spur/pinion it would overheat the motor and ESC right away. With the clutch, I ran an entire 5000 mah pack and the motor never went above 90 degrees and the ESC ran about 120-125.
So, would the clutch allow for more motor options?
