05.02.2008, 08:45 PM
Chassis is on ebay, same ebay id as my user name....
05.04.2008, 01:51 PM
Originally Posted by suicideneil
Permission to ask silly question:
Is it still possible to order the RaceBomb chassis (or anything for that matter), as a special order thing? Any plans for the future- Erevo or Emaxx 3905 wise?...
I still have parts, but no chassis plates. "Cold Fusion" wanted to do all of my plates at one time, and said they could handle it. Turns out they only made 1 run and couldnt handle it, which left me with no machines set up to cut them anymore. I still have my CNC equipement, just nothing for the plates. I have alot of new stuff no one has even seen, but the second I show it off....its always on someones assembly line ready for sale. So, it becomes quite disgusting to come up with new stuff only to have it stolen and not get the credit/profit for it. Ive seen direct 100% copies of my stuff in magazines with zero credit from it. The only stuff I show now is the stuff thats a nightmare to duplicate, so atleast I will make people work for it. I started making lowrider parts (old school Impala's, etc.) and made stuff for $100K cars....stuff that was never done. Within a month, someone copied it completely, after I did the 6,000 lines of G-code to machine it. I have some really trick parts now, but have no intrest in showing them off to have someone copy em.
05.04.2008, 02:16 PM
Damn, I can understand how you feel. Dare I ask, have you ever looked into getting the designs patented, then releasing them once no-one can legally ripoff your work? I know the patent process is somewhat long winded and complicated, but it would be travesty to have so many good designs go to waste...
05.04.2008, 02:27 PM
A Patent can get expensive and it only takes a few changes for someone to get his own patent as well based on the same design.
05.04.2008, 02:35 PM
Are you still going to make your truggy chassis? It makes a fine HV chassis and I'm loving mine. Can you make the center motor mount and bearing support mount? I need 3 center motor mount. One for a normal 25mm motor mounting space for normal M3 screws, one for Neu that uses M4 type screws and one for a Lehner 22 series 30mm bolt pattern. I would also like the mounts to be around 5mm lower.
Regards.
05.04.2008, 03:01 PM
exactly.
Lutach, I sent ya a PM a couple weeks ago bout the mount.
I still have the truggy's here, my main problem is finding time to get everything back in line for em. I have probably 15-20 sets carbon fiber chassis,towers and braces already done for em.
Ideally what I would like to do with the truggy is have a couple more guys that can actually machine parts with quality, and have an idea of what the thing is...and build the best electric race truck ever made. There is alot more to the truck than most people know, it can be adapted to nearly any truggy suspension and all kinda cool stuff like that. I wouldnt mind other places to make parts for the truck for example, I am sure Mike could come up with some cool slipperential ideas for it, etc. Its the best platform available period, its made for electric from the get go. I have all the files of course, so the parts can be easily adapted. I just know I dont have the time to build every inch of every truck and give it the support it needs to actually let people race it without letting people down at the track. If I am putting it out there as the best race truck, I wanna be able to have someone parts in hand the next day if they need em.
05.04.2008, 03:27 PM
exactly.
Yes, I replied and gave you my e-mail address and I also sent you an e-mail for you to send me the file. Your chassis are rock solid and I don't think racers will need any support from you. They will need support for everything else like the drive train they use. Brian the HV saga is just beginning and your chassis can easily fit 10-12S lipos. I will see if the center mount can be made and if so, I'll try it out in my truck first and then buy a few of the carbon fiber sets and add the Kyosho ST-RR suspension on one and try out a RC8 suspension on another. It should be some fun projects and all will be HV. How many people so far still have your chassis that actually races them?
05.04.2008, 03:41 PM
5 of em are out there, all of em are still kickin as far as I know. 4 in the US and 1 in France. I tried to break it and I never had a problem. The weak point is the brace to tower mount, thats the only part I have ever seen break. Its an easy fix, so it isnt catastrophic by any means. The cast plastic ones were the weakest(most were cast), I ran billet plastic on mine and they were unstoppable. Its perfect for the HV plans you have, with room to spare. I will email the files to ya asap.
05.04.2008, 04:27 PM
I will keep making videos and show proof of how easy it is to run your truggy with an HV set up. I can't thank you enough for making an amazing conversion. You and Mr. C are definitely pioneers of the truly 1/8 scale electric conversions. I will wait for the files and will you be able to make it or should I ask Mike to do them for me?
05.04.2008, 06:52 PM
Its probably gunna be quickest if Mike can get em done for ya, I keep getting swamped with stuff. I have been tryin for 4 weeks to get a chance to finish a simple part, just cant get the time to work on it. Either way, we will get you runnin.
05.04.2008, 07:13 PM
Sounds good. I will wait for the files and I will get some pictures posted.
05.06.2008, 03:27 AM
05.06.2008, 09:44 AM
Cool man, thanks for sharing.
05.10.2008, 01:31 PM
07.01.2008, 06:35 AM
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
