mwry13
mwry13's Avatar
05.05.2008, 01:18 PM
In breif,
say we have 2 7.4 volt 5000 Mah packs
If we have both packs in Series, the MaH stays the same but the voltage is doubled to 14.8
if we have both packs in para, the voltage stays the same but the MAH is doubled to 10000 Mah
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
Neu 2s 5000 Mah 30c Batteries
M11 DSSS
Airtronics 358
Socal
rcsammy
buggy beater
rcsammy's Avatar
05.05.2008, 02:53 PM
ok, thanks thats alot easier to understand than how the guy on the maxamps chat thing explained it
so what difference does more or less voltage and more or less mah make to the performance of the car/battery? then hopefully i can work out which batterys to go for, im sure you guys could probably just suggest one but it would be handy to know why its the best:)
  Send a message via MSN to rcsammy
Motoman
Motoman's Avatar
05.05.2008, 03:58 PM
Basically, if you kept everything else constant (like motor,gearing,...), then more voltage means more motor rpms so faster speeds. More mah or capacity, means you have more disposable energy and so the vehicle will run longer on a single charge.
you need to find the right balance of both voltage and capacity that works best for your application. Consider size, weight, voltage, capacity, expected speed, expected runtime, brand, and price. Usually 1/8th scale buggies run great on 4s. A light setup in 4s would probably be around 4000 - 6000mah, but some people use bigger batteries like 8000mah. The 8000mah batteries are great but as I found out they are too big for an 1/8 scale buggy both size and weight.
hope that helps.
mwry13
mwry13's Avatar
05.05.2008, 07:59 PM
Also cant forget about amp draw...
Lipos are rated in terms of there C rating. The higher the C rating, the more amps that pack can produce under high stress conditions.
say for example you want a motor that will spin about 30,000 rpms which is a good starting point.
If you use a 4s pack with a 2200 kv motor you'll spin about 32,560.
if you want something comparable to 30,000 rpms on a 5s setup you'd have to run about 2000 KV motor
The RPMs in the end will be about the same but using the higher voltage of a 5s pack will yeild less amps drawn and when less amps are drawn... less heat is generated.
so in short, you can get a setup for any RPM range you want, it really depends how much you want to spend on a speed control, that decides it imo...
High voltage Speed controlls (anything over 5s ) are usually expensive and exotic... aka mgm
Lower voltage speed controlls are reasonable but you usually generate considerable heat when using them... aka mamba max
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
M11 DSSS
Airtronics 358
Socal
rcsammy
buggy beater
rcsammy's Avatar
05.06.2008, 11:39 AM
i think aslong as the price is reasonable it will be a MMM
so what sort of packs should i be looking at from here? www.maxamps.com
so far from the info everyone has given i know i need 4/5s atleast 100A continuous
personaly i would like similar performance to a nitro buggy amd runtimes long enough to make a 15 minute final(so around 20 mins to be safe) and at the moment it looks like im going with a MMM
or even better would be if i could buy just one pack(even if it is more expensive) that will last me 3 qualifiers and a final so 30 minutes(35-40 to me safe)
are either of those acheivable with the kind of setup im looking at?
05.06.2008, 12:00 PM
Ok, given my experience, I would suggest to use a MMM, and a medusa 36/60/2000, in the V2 line. Run that on 5s lipo and you will have a cool running system with plenty of power for a buggy. I run a 36/60/1500 on 6s lipo in a hyper8 buggy and it does fine. Very nice motors for the money. I would stay away from maxamps, as there are other battery choices that will perform better and cost about the same.
So my suggestions, with links:
MMM : http://www.rc-monster.com/proddetail...steresc&cat=21
Medusa 36/60/2000, found on this page: http://www.medusaproducts.com/motors...MR036060XXXX-5
Battery : http://www.rc-monster.com/proddetail...5S_3700&cat=18
The rcmonster store can also provide you with the motor mount and battery tray, plus the pinions and other odds and ends that you need. You could buy a neu 1512 motor from there instead of the medusa, but the medusa is on special right now.
rcsammy
buggy beater
rcsammy's Avatar
05.06.2008, 05:51 PM
yes i do plan to get the motor mount and battery tray from rc-monster
are there any similar motors that are available through rc-monster so i could make the whole purchase from one shop as i imagine shipping to UK and customs will cost me alot
what runtimes do you get with that setup? i was expecting to need a higher mah battery
