05.05.2008, 04:16 PM
The middle pin is used for 2s packs, with the balance wire connected between the first and second pack.
The outer pins are used for 3s packs. The 1st pin is connected between the first and second battery, and the 3rd pin is connected between the second and third battery. If you connect it backwards, it won't charge. Nothing will blow.
Ok, so on a 2s pack, the wire goes in the middle of the plug, and on a 3s pack the wires go on the outside pins. Which way do the 3s wires go? Would the balance wire between the 1st and 2nd cell go on the left side (fuse side) or the right side(led side)?
Many thanks, as I have a 2s pack charging at the moment!
