skellyo
skellyo's Avatar
05.08.2008, 09:22 AM
Originally Posted by crazyjr View Post
I been thing of a neu 11xx in 1/10 for a while, the main problem is that the motor screw holes are different size and spacing. Its a 1/8 inch shaft though, so all you need is an adapter. I figure anything from a 3500 to a 5000kv, would be right for the buggy on 2s. The 1107's look promising, I got one in a Mini Quake (1107/2y (3400kv)) and its waaaaaay too much. I been thinking of putting it in my T4 with the MM and gearing it for about 40 on 2s. I been meaning to ask if Mike could do a Motor plate adapter for a 370-400 sized motor to 1/10 application
This should work to adapt it for you:
http://holmeshobbies.com/product.php...&cat=19&page=1
crazyjr
crazyjr's Avatar
05.08.2008, 09:55 AM
Thank you much skellyo, Now i can see if the motor is as strong as i think it is
