DickyT
05.08.2008, 07:28 PM
Originally Posted by ilpufxit View Post
When I ran into the same problem programming a Quark, it turned out I had my throttle setting reversed on the tx.
I set defaults 0n the radio before I began. I just tried reversing it though and same thing, it just can not find neutral.
The fan is getting broken in nicely. I think it is silly to run the fan during castle linking, but hey.
Pdelcast
Pdelcast's Avatar
05.08.2008, 07:34 PM
Ah, the fan just runs all the time when there is power on the bus... it is silly, you are right. :)
I haven't heard of any issues with neutral programming -- can you put a servo on the throttle channel to make sure it isn't doing something weird? (make sure you have both forward and reverse (brake) throw, good center position, etc.)
Patrick
