05.09.2008, 10:06 AM
For the PSU: Some people use light bulbs, but they are relatively fragile and I don't like getting broken glass in my skin when I reach into my toolbox. Maybe nothing needs to be loaded - there could be some sort of other turn on mechanism. Hard to say though...
For the shimming: There should be no side to side motion - that's probably what's causing your problem. The pinion should be fully meshed into the ring with NO play, but make sure it still runs freely, especially after you get the case together.
brushlessboy16
brushlessboy16's Avatar
05.09.2008, 03:02 PM
PSU- The supply needs one of the lower voltage circuits pushing current to activate... i connected the green wire to a ground, still nothing so im hoping i can find a way to load it down a little bit :D
As far as diffs go, I want to but just a pinion but they dont sell the individual parts, so im gonna get a helical cut gear set anyway (they sell the pinion and spur serperately) But i cant seem to find any shim kits on tower... am i looking in the wrong place?
